Hello,
this is a new problem that did not happen in Mailwasher 6. Characters that are not available in the English alphabet are not shown correctly in all places. Please check the attached screenshot, where you can see that the same text is displayed once correctly, and three times incorrectly in MailWasherPro 2010. Currently, these letters are displayed correctly only if the Subject is UTF-8 or ISO-8859-1 encoded.
Ulrich
Problem displaying non-English chars
- Ulrich
- SNAG-2010-08-01-01.png (111.21 KiB) Viewed 7639 times
- Ulrich
Re: Problem displaying non-English chars
Hi Chris,
I can certainly send some future spam - those messages shown in the screenshot were already deleted.
As soon as I have some new cases, I'll forward them.
Ulrich
Ulrich
- gerohl
- Active Albatross
I have the same problem with å ä ö, they show as ? ? ? in the subject field but it looks fine in the preview pane.
This has been fixed now in 1.0.10 http://forum.firetrust.com/viewtopic.php?f=50&t=6858
Also Ulrich we've added an option to select a different display font, you should find either Arial or Verdana better to read.
Edit : Gert, this also fixes the delete problem you were having in the other topic.
- gerohl
- Active Albatross
- Gert
Thanks for that Chris!rusticdog wrote:This has been fixed now in 1.0.10 http://forum.firetrust.com/viewtopic.php?f=50&t=6858
- Gert
- gerohl
- Active Albatross
It took a bit longer to delete them than before but the washing was much faster.
Cheers - Gert
Chris, I've just deleted 250 emails on 6 accounts and it went smooth and I didn't get any errors...sorusticdog wrote:This has been fixed now in 1.0.10 http://forum.firetrust.com/viewtopic.php?f=50&t=6858
Cheers - Gert
