Filters not imported from MW 6
Graeme
Fri Aug 06, 2010 1:36 pm
I have just bought and installed MW 2010. My friends and blacklist imported OK from MW 6 but not the filters. Did I do anything wrong or do I have to recreates them all again? :(
Re: Filters not imported from MW 6
Fri Aug 06, 2010 1:52 pm
You didn't do anything wrong, the filters do not import due to the minor differences in the v6 and 2010 filter tool.
All is not lost though, if you open v6 and 2010 side by side (both can run at the same time with no problems) you can use copy/paste to get your filters across. you may have to tweak a few of the settings but the text should be the same. If you have regex filters there may be a bit more tweaking needed but not too much and the new regex engine has excellent documentation and a test utility that make it a huge improvement over the v6 regex.
http://www.regexlab.com/en/deelx/introidx.htm
If you have a huge amount to do you might look at directly editing the filters.xml file and just adding them to that but it isn't usually worth the extra effort over using the filter screen.
Graeme
Fri Aug 06, 2010 3:30 pm
Thank you, much appreciated.
It is not a huge task for me but before I recreated my filters I wanted to make sure I wasn't missing how to import them from MW 6. I had to buy a new monitor recently and went for a 24" one, this gives plenty of screen real estate to easily do a side by side cut and paste :)
Fri Aug 06, 2010 3:44 pm
You'll love what MW looks like in a wide window, you can get a full set of columns and the mini sidebar or most of the important ones and the full spam tool sidebar.
Click twice - slowly to get scrolling controls.
Fri Aug 06, 2010 3:52 pm
The image resized :mrgreen:
I had to laugh though....just what are you trying to say Stan.
Fri Aug 06, 2010 4:02 pm
Don't blame me... You folks are the ones that put that line in a BOLD font, not me!
Only thing that gets us lively in the bedroom any more is when a spider or lizard drops in for a visit, don't want a pill for more of that kind of action!
