MWP 2010 slow on exit again...
Compudoc
Mon Aug 16, 2010 4:26 pm
I know you had taken care of this at one time, but I have noticed that once MWP2010 closes that it seems to "hang up" my system ESPECIALLY when opening Outlook Express either within or outside of MWP2010. If I have other programs running minimized, they seem to freeze for about 5 seconds as well.
Just wanted to mention it - it's not a "show stopper". Maybe it has to do with the .NET items you mentioned on the start up side...
Re: MWP 2010 slow on exit again...
Mon Aug 16, 2010 4:30 pm
That's an odd one, certainly it'll be all MailWasher and nothing in the .NET framework. If you can make the problem and then go Help >> Send Support Logs >> enter chris as the Ticket Number >> Send Logs.
If possible if you can detail the exact time, maybe synch a wristwatch with the PC clock so you can tell exactly the time it occurs between,
Compudoc
Wed Aug 18, 2010 4:02 pm
I will try to get this to do ASAP...
What's so funny about peace, love, and understanding - Elvis Costello
