Hello everyone,solitaired
I have been using MailWasher for a while now and have recently encountered some challenges. I cannot scan new emails and the filters are not working as expected
Is anyone else having similar issues? Please provide me with any guidance or advice on this issue.
Find solutions to MailWasher ssues
- jacobmmikesell
Last edited by jacobmmikesell on Fri Apr 18, 2025 11:54 pm, edited 1 time in total.
Re: Find solutions to MailWasher ssues
Do you mean that no emails show in MW at all? if so, if you made no changes yourself, possibly your firewall updated and is now blocking the mail server that you use to check mail for this account in MWPro?
If all looks OK, and the email account works in your email program on the same PC, probably the best option here is to try deleting the problem email account and re-importing it....
(First though, click File>>Export and save a copy of your settings to file for a backup)
Settings available here (for most ISP's but not personal domains) if you need them: http://www.emailsettings.email/
