Update has bug
wizard7
Update has bug
Sat Aug 21, 2010 12:30 am
I upgraded to the latest ver 1.0.15. Now when I open a mail window, the mail window sits so the top of the window where the close "X" is located is out of sight and the window CANNOT be moved in any direction. :no see attachment. I use windows XP. The previous ver before update worked fine. Love the new MWPro 2010. Also the update does not seem to load any faster, even though it was supposed to.
MWP window.jpg (218.41 KiB) Viewed 5178 times
Re: Update has bug
Sat Aug 21, 2010 1:49 am
Hi there
If you right click the Preview Pane icon in your Task Bar can you select the Move option and move it down from there.
The startup loading improvements is only when people have large Friends List and Blacklists. If you have less than 1000 I don't think you'd notice much difference.
wizard7
Re: Update has bug
Sat Aug 21, 2010 4:30 am
I have tried the "MOVE" function from my windows task bar and it will NOT move the window. I get the double arrows and place it in various locations on the window and it will NOT move it just disconnects after I try to move it.
To close it I have to move all the way to the bottom of my screen in my windows task bar and right click to close it. What a pain! Before the update I could move the open window all around and just click the "X" to close it. :scratch
Can I go back to the previous ver. before the update until you get this fixed? and how do I do it. Thanks
Re: Update has bug
Sat Aug 21, 2010 4:36 am
You mean you don't see an icon like this when you preview an email ? There should be one.... :scratch
wizard7
Re: Update has bug
Sat Aug 21, 2010 4:42 am
Yes, I have tried the "MOVE" function from my windows task bar (many times) and it will NOT move the window. I get the double arrows and place it in various locations on the window and it will NOT move it just disconnects after I try to move it.
wizard7
Re: Update has bug
Sat Aug 21, 2010 4:47 am
OK, here is what I had to do. I used the move function, BUT i had to use my keyboard "arrow" keys to move the window. It does not work with mouse. In case anyone else has that issue. Maybe a fix for the next update. Thanks for your help. Still love this new version. :D
Re: Update has bug
Sat Aug 21, 2010 4:48 am
OK great :)
Not sure what caused it to open all the way up there, the update doesn't overwrite settings and so it should have remembered the proper screen position
