Display problem
crawphil
Display problem
Sun Aug 22, 2010 2:30 am
Having downloaded MailWasher Pro 2010, I find that in the Inbox and Recycle Bin screens, the characters of the column headings and emails reported are shown as squares. In the preview window of the Inbox screen, the display is correct.
I would much appreciate any ideas on resolving this problem.
Many thanks.
Re: Display problem
Sun Aug 22, 2010 5:22 am
What language do you have set?
Could you post a screen-shot to the forum? There is an upload attachment menu just below the posting area.
crawphil
Re: Display problem
Sun Aug 22, 2010 5:54 am
Thank you for your reply.
My language setting is Proper English
A screen print is attached.
anniebrion
Re: Display problem
Sun Aug 22, 2010 5:56 am
Do you have Calibri or Arial fonts installed?
crawphil
Re: Display problem
Sun Aug 22, 2010 6:01 am
I have Arial fonts installed but not Calibri fonts.
Do I need both?
anniebrion
Re: Display problem
Sun Aug 22, 2010 6:09 am
IIRC the grid uses Calibri but falls back to Arial if it cannot find Calibri.
Have you tried un-installing (Keep user data when prompted), then re-install?
Not sure if repairing .net would help.
crawphil
Re: Display problem
Sun Aug 22, 2010 6:13 am
I have tried uninstalling and reinstalling but without success.
I'll have a go at repairing .net. Thanks.
Re: Display problem
Sun Aug 22, 2010 6:37 am
If the reinstall doesn't work try these settings to see if any make things better.
crawphil
Re: Display problem
Sun Aug 22, 2010 9:22 am
Very many thanks to stan_qaz and anniebrion for their prompt assistance. The problem was resolved by the repair of .net.
Re: Display problem
Sun Aug 22, 2010 5:05 pm
We aren't sure on the cause, but yes, repairing .NET seems to be the answer. With the fonts in the grid, if Calibri isn't found, MailWasher will use Arial I believe.
anniebrion
Re: Display problem
Sun Aug 22, 2010 7:16 pm
crawphil wrote:Very many thanks to stan_qaz and anniebrion for their prompt assistance. The problem was resolved by the repair of .net.
Brilliant news, glad to help :)
