Interesting screen corruption
dvdvnr
Tue Aug 24, 2010 8:22 pm
Just had this rather interesting screen corruption. I think I'd just done a wash of unwanted emails.
Screen Corruption 1.jpg (226.51 KiB) Viewed 5362 times
As you can see, one of the "washed" emails was still visible with the delete tick still showing. I have blurred the email addresses for security.
If I collapsed all of the different status sections then it was still displayed:
Screen Corruption 2.jpg (36.9 KiB) Viewed 5362 times
Minimising MW didn't fix the problem. I had to close and restart it.
David
anniebrion
Re: Interesting screen corruption
Tue Aug 24, 2010 8:41 pm
This is a known problem with the grid software that is used by MWP, this is supplied by a 3rd party and as such is difficult to get fixed :(
Tue Aug 24, 2010 8:49 pm
If scrolling doesn't clear the issue, you can just clear the grid by pressing C then Y on the keyboard, then just recheck the account. Much faster than restarting.
dvdvnr
Tue Aug 24, 2010 10:17 pm
anniebrion wrote:This is a known problem with the grid software that is used by MWP, this is supplied by a 3rd party and as such is difficult to get fixed :(
Thanks anniebrion - ah, 3rd party software, fine until it isn't! :)
Tue Aug 24, 2010 10:23 pm
It may yet be our fault in how we're using it, yet to be fully proven. :oops:
Though we're sure we're doing everything right so far.
dvdvnr
Tue Aug 24, 2010 10:30 pm
rusticdog wrote:It may yet be our fault in how we're using it, yet to be fully proven. :oops:
Inconsitencies between how they say it works and how it actually works? Documentation at least 1 version out of date? Situation absolutely normal then (going by my experience) :roll:
