Sequential vs Simultaneous mail checks
- kmiles
in the older version of Mailwasher Pro, you had a setting to tell Mailwasher to check your email accounts either simultaneously, or not (ie. sequentially). That made for a faster check if you had a high-speed line. I don't see that setting in the new program. Anybody know which way it checks? The log implies a sequential check - which is an issue, cause right now some of my accounts are not reachable, and it seems to be waiting for a time out to occur before it checks the next account. With simultaneous, it checked them all at roughly the same time, and I did not have the long delay to check all the accounts.
- anniebrion
Re: Sequential vs Simultaneous mail checks
Here you go. Drag the slider all the way to the right for ALL:
- 24-08-2010 4-09-16pm.png (128.23 KiB) Viewed 3417 times
- kmiles
Thanks. I didn't associate that with the number of simultaneous checks. Appreciate that!
