New MailWasher Pro 7.12.6
Fri Aug 27, 2010 6:36 pm
A new version of MailWasher is now ready, 7.12.6
To get the update just go Help >> Check for Updates ... if you're told you are already up to date but you know you are not, then update manually using this link
Download Link if needed http://cdn.firetrust.com/downloads/mail ... _12_06.exe
Changes in 7.12.6:
OAUTH removed for GMail accounts
Added option to retrieve last 2 days emails for IMAP
Fix for POP accounts incorrectly displaying fetching information (last xx days)
Fix for crash for badly formatted email
Fix for crash when loading Recycle Bin with a badly formatted email
Fix for crash when auto-deleting messages
Updated Contact Importer
Older releases :
Changes in 7.11.0:
Added OAUTH support for Yahoo accounts (IMAP only)
Added OAUTH support for GMail custom domains
Fix for accessing IMAP folders containing non alphanumeric characters
Fix for IMAP logout
Fix for Hotmail accounts failing to check all messages
Fix for Yahoo and POP PIPELINING failing
Fix for moving IMAP emails when folders contain spaces
Fix for IMAP FETCH command not being properly formed
Fix for MailWasher not storing Read/Unread between restarts
Fix for new mail notification increasing in count
Fix for retrieving IMAP folders when passwords contain special characters
Updated SSL libraries
Updated Account and Contact Importers
Changes in 7.9.0:
Fix for IMAP account testing reporting success on a failure
Fix for crash when closing Search during a mail check
Fix for MailWasher de-registering itself
Fix for Recycle Bin not displaying all emails logged
Fix for Tell A Friend incorrectly formatting email
Fix for importing accounts from Outlook 2016
Fix for MailWasher getting hung when STOP is pressed
Fix for grouping sort being altered by clearing the message list
Fix for Profanity Filter crash
Fix for database VACUUM failing
Fix for crash when registering with Japanese characters
Fix for 'Browser not supported' message when trying to authenticate an OAUTH account.
Fix for Friends List and Blacklist not importing
Fix for case sensibility when grouping by subject
Fix for Restore triggering IMAP command
Fix for MailWasher launching as Admin after a Standard User install
Fix for manual clearing of Recycle Bin not clearing All Logged Emails
Fix for invalid EHLO characters during SMTP sessions
Fix for crash when Preview Window is out of screen bounds
Fix for crash when loading certain emails in Recycle Bin
Updated SQLite
Changes in 7.8.0:
You can now group by Arrived or Sent. The groups are layered as Today, Yesterday, Last Week, Last Month, All Time
Added Profanity filter
Added 20, 30 and 60 second intervals to the balloon notification
Reply-To added to Custom Filters
Added Delivered-To to Custom Filters
Added Helvetica as a selectable font
MailWasher minimum height reduced
Added ability to Move deleted messages to specified IMAP folder
Fix for 'Show email header' and 'Show action buttons' not saving correctly
Fix for crash when quickly moving between emails
Fix for extra whitespace being present when Preview Pane is positioned to the right
Fix for MailWasher sending large IMAP commands
Fix for MailWasher not handling incorrect IMAP logons correctly
Fix for special characters in IMAP passwords
Fix for Hebrew not displaying properly
Fix for YahooGroup emails not always getting triggered by Custom Filters
Fix for Tutorial video
Fix for Updater.exe crashing on Windows 8
Fix for crash when switching user accounts
Fix for MailWasher closing windows of other applications
Fix for crash when viewing certain email content
Fix for crash when selecting Report Bug, lol
Fix for text being cut off in Help & Informati
Fix for bouncing via OAUTH
Misc small tweaks and fixes
Changes in 7.7.0:
Custom Filters 'Message Body' now applies after Base64 messages are decoded
OAUTH option now properly adjusts for SMTP
Option to disable OAUTH added
Fix for OAUTH and Recent Mode
Fix for certain SSL accounts failing to logon
Fix for obscure crash when setting scroll wheel behaviour
Changes in 7.6.0:
Added support for Google OAUTH
Added SIZE to Custom Filters
Custom Filters now support IS operator
Added READ column checkbox to mark/unmark all emails as Read
MailWasher now periodically runs a database VACUUM
Quick Reply now properly uses Reply-To
Fix for MW not matching UTF8 encoded email addresses
Fix for Blacklist and Friends List editing
Fix for Recycle Bin not updating on date rollover
Fix for blank/mismatched IMAP email
Fix for Download Read Email resetting on install
Fix for Cyrillic characters in database path causing database failing to open
Fix for UTF8 encoded Sender not matching Friends List/Blacklist
Fix for MailWasher not unfolding Long Header Fields (SpamAssassin fix)
Fix for non ASCII characters in data path
Fix for apostrophes in URLs
Fix for Scroll Wheel not scrolling message when switching to HTML view
Fix for URL warnings not showing in HTML emails
Fix for 'Always show event log' not saving between sessions
SQLite version updated
Updated Account Importer
Changes in 7.5.0:
http://cdn.firetrust.com/downloads/mail ... 022015.exe
IMAP accounts now by default do not load Read emails
Installer now adds/removes Taskbar icon
Added TLS for POP and IMAP
Database upgrade for compatilibity
Fix for IMAP accounts with spaces within the password
Fix for international characters in Quick Reply and Quick Forward
Fix for IP address parser detecting software version number as IP address
Fix for Startup shortcut not being properly added on install
Fix for wrong default language file loading on startup
Fix for IMAP folders containing special characters
Fix for Preview screen jump when right clicking on a URL
Fix for log files not cleaning up properly on new year rollover
Fix for no HTML loading in emails when HTML is present
Fix for some emails showing blank in message preview
Fix for Mobile Synch with IMAP accounts
Removed option to Synch with Desktop until fully working
Splash screen text added to Language files
Chinese Traditional and Simplified added
Improved Installer language support
Contact Importer tweaks
Changes in 7.4.0:
Recycle Bin can now optionally display all logged emails, not just deleted.
Sync support for MailWasher Mobile 2.0 (to be released soon)
Added more information into Email Info screen
Improved Contact Importer
Improved Account Importer
Improved Sync for MailWasher Mobile
Fix for MW not downloading enough data on message preview
Improved Account Setup steps for account creation
Updated Language files
Updated DNSBL files
Updated Account Server files
Changes in 7.3.0:
Envelope toggle for showing/hiding emails is now sticky on restart
Added DELETE button into message preview icons
Fix for erroneous crash reports being triggered on Windows 8
Fix for Startup shortcut not being added properly during a full install
Fix for duplicate entries in Friends and Blacklist synchronisation
Fix for MailWasher automatically scrolling past the VIEW HTML button in message preview
Fix for MailWasher not automatically resizing message preview icons when space is too small
Friends List now has more authority by default (200)
Updated language files
Changes in 7.2.0:
Please Note : If you use screenreader software with MailWasher, you will need to go into Settings > General > Performance > and select the option Enable for screenreaders. If this is not selected your screenreader may be unable to read email information.
Synch checks to now run daily if MailWasher is left running
Added checkbox into Delete column header to mark all emails for delete
Added Performance option Enable for screenreaders, defaults to Off
Fix for that awful awful Recursive Call to UI Automation crash
Fix for Blacklisted domains autodeleting when sender address is on Friends List
Fix for crash when removing entry from blacklist
Fix for crash on suspend
Added extra logging for crash when opening certain URLs
Database upgrade to prevent duplicate entries in Blacklist and Friends list
Changes in 7.1.0:
Added ability to Synch MailWasher Pro settings and accounts between PCs
Added ability to Synch MailWasher Pro settings and accounts with MailWasher Mobile for iOS and Android
Added ability to view emails in HTML
Added slider to Performance settings to control how much text is sent through Quick Reply/Forward
Improved encoding for Quick Reply/Quick Forward for web based email clients
Improved Sent and Received columns not updating on date rollover
Fix for oldest message being selected automatically when using IMAP account
Fix for Reset Learning not deleting Spam Corpus
Fix for navigation keys not responding when opening Preview Window
Fix for PopUp Notification not clearing when no emails present
Fix for MailWasher remembering bad passwords
Fix for crash when copying to clipboard throws an exception
Fix for crash on account alteration
Fix for crash on Tell A Friend
Changes in 1.20.0:
Added Sender column
FirstAlert performance improvements
Increase Filter Rule limit to 500 filters
Preview Window can now be opened when Preview Pane is enabled
Added message to WhoIs screen when domain is unrecognised
Fix for contact importing on 64bit systems
Fix for contact importer not importing all entries
Fix for crash on certain emails in FirstAlert
Fix for crash on startup when Window Size gets massive
Fix for Preview Pane jumping after opening a URL
Fix for Import not properly overwriting files
Addition of Uninstall Questionnaire
Misc small tweaks
Changes in 1.11.0:
Added ability to Import and Export settings, found under File menu
Allow AutoDelete to be set to lower values
Added basic AntiVirus disabling recommendation on certain errors
Updated Language Files
Fix for Contact Import on 64bit
Fix for High Contrast displays
Minor UI tweaks not even worth mentioning
Changes in 1.8.0:
Added Polish Language
Fix for Croatian language not loading
Installer tweaks and improvements
Changes in 1.7.0:
FirstAlert accuracy improved
Next/Previous now positioned at top of Preview
Email preview now shown by default on new install
Restore logic changed so that if the account no longer exists the fallback account is used
Auto mark as read delay no longer restricted to single digit
Delete column checkbox is cleared after washing mail
Delete column checkbox is cleared after search is cleared
Fix for accent characters not appearing correctly in the source view
Fix for blank emails when message is digitally signed
Fix for delete popup constantly appearing
Fix for filters with language rules triggering when they shouldn't
Fix for some memory leaks
Fix for full email not always downloading on scroll
Fix for URLs with exclamation points
Mail preview options "Show email header" and "Show action buttons" now work with the windowed preview
Fix for crash when testing accounts with spaces in the password
Fix for crash on account timeout
Small UI tweaks
Changes in 1.5.0:
http://mailwasher2011.s3.amazonaws.com/ ... 122010.exe
Theme alterations
Added Email Info section, including summary of links, attachments and more
Added WhoIs lookups from Email Info screen
Added checkbox to Delete column to select all emails for delete
Addition of Delete column choice in Settings >> Display >> Inbox
Custom Filters now get added after the selected filter
Spam Throttle can now select 9999 lines per email
Increased the delay of automatic checking on Resume to 30 seconds
Added autodelete options for Spam Tools
Fix for crash when detecting ThunderBird install
Fix for closing parenthesis in URLs
Fix for Always Show Event Log not saving
Fix for blank message in Preview Pane when Content-Location: is set
Fix for new mail popup title bar not restoring MailWasher on click
Changes in 1.4.0: aka Drunk Monkeys Make Bad Staff
MailWasher now stores and recalculates time since last check after Sleep
Fix for Icomparer and Index Out of Bounds crashes
Fix for crash on new mail notification
Fix for crash when blacklisting multiple entries
Reporting column added to Inbox >> Display settings
Fix for new mail notifications incorrectly triggering on spam emails
Fix for new mail popup stating double amount of emails arrived
Fix for hang on filter re-evaluation
Fix for crash on marking email as read
Fix for crash on selection of empty rows in mail grid
Fix for crash on Registration check
Inserting filter rules now insert below the currently selected rule
Fix for Friends/Blacklists not matching when Learning disabled
Fix for GMail emails disappearing in grid when checking multiple folders
Fix for text/enriched; emails showing no content
Fix for new mail notification always stating 4 new emails
Changes in 1.3.0:
Added ability to hide emails
Added Search to custom filters
DNSBL service added to tooltip
New mail popup balloon added
New mail popup can now be called up via mouse over the tray icon
New mail popup duration option in Settings >> General >> Notifications
Added ability to cycle through deleted emails
New languages, Norwegian, Armenian, Spanish
Improved account importer
Cleanup routines now run more often and not just on exit
Fix for characters displaying incorrectly in Preview Pane
Fix for asterisks breaking URLs
Fix for corrupt updater.ini file causing updates to always fail
Fix for crash when loading corrupt Friends/Blacklist entry
Fix for blurry text in Filter Edit screen
MailWasher now follows selected Filter when reordering
Minor display tweaks when using bright green/yellow colours
Send Support Logs window can now be resized
Fix for McAfee AV header that was being displayed in the plain text preview
Fix for Reporting options not saving properly if exiting MW from Settings screen
Fix for Email Program translation text not updating
Tweaks to Spam Reporting screen
Removed Status Bar icons (Delete/Hidden emails) when in Recycle Bin
Status Bar icons now zoom in relation to Font zoom
Ctrl+A nows selects all email even if it doesn’t have focus
Fix for empty preview on certain messages
Improved IMAP logon errors in Event Log
Added (albeit useless) error when database is corrupted
Error Dialogue boxes should now identify MailWasher as the crashing program
Misc small tweaks and fixes that we can't remember
Changes in 1.2.0:
Added Spam Reporting
MailWasher now runs as a single MailWasherPro.exe process
Speed improvements
Added some new mail notification icons
Added new Tray icon in Display Settings
Added Pirate Language and Icons
New version of Xceed Data Grid
Double clicking over Delete column no longer triggers Preview Window
Added some language encodings to Custom Filters
Registration now checks on port 80 not 4088
New HTML parser for URLs
Disabled Automation Peer for DataGrid
Recycle Bin clean up routine only called once a day on exit
Fix to stop MailWasher freezing when email program launches
Fix for DNSBL changes not saving if MailWasher is closed still in Settings screen
Fix for slow loading of emails in Preview screen for some users
Fix for empty UID messages when moving emails to Recycle Bin
Fix for Support Logs sending wrong information
Fix for automatic updates not being detected
Fix for crash when IMAP account fails an account test
Fix for crash when launching mail program
Misc small fixes and tweaks
Help file improvements
Language file updates
Changes in 1.0.67 :
Fix for crash on startup when Custom Data path is selected
Fix for crash in new mail notification
Fix for installer failing on some machines
Fix for evaluation spinner not resetting on FA timeout
Changes in 1.0.63 :
Added option to choose a custom data folder
ClearType option added into Settings >> Display >> to disable
Added Select All into right click menu in Filter fields
Event Log to show most recent entries automatically
Installer changed to start .NET 4 version of font cache
Help >> Registration >> now reloads the License from the server upon entry
Removed Recycle Bin purge on startup
Fix for MailWasher preventing hidden TaskBar from showing
Fix for Display Layout not setting to Custom when Preview Pane closed through View menu
Fix for borders on Preview Window
Fix for bounce button showing in Recycle Bin
Fix for Friends/Blacklist not matching when @ is in display name
Fix for some emails not showing attachments
Fix for emails missing From/Subject/To in Recycle Bin
Fix for empty FirstAlert errors
Fix for column widths increasing
Fix for MailWasher stalling when resuming from Sleep
Fix for automatic updates not being detected on some machines
Fix for old QuickStart shortcut not being removed
Fix for hang caused by 'An item with the same key has already been added'
Fix for crash that can occur on StartUp after a clean install
Fix for crash that can occur when Classifying emails
Fix for crash on Exit
Fix for crash in TellAFriend
Fix for crash at startup
Fix for crash on corrupt Registration File
Changes in 1.0.50 :
New Tab and Frame theme
New colour choosers for Frame added into Settings >> Display
Added optional pre-loader to load files into memory before MailWasher starts
Added stock Layouts in Display Options : Default, Laptop, Widescreen, Custom. Note, in Custom you also have the option to switch off the buttons and other header data in the Preview screen
Improved Startup time
Email grid now takes focus immediately so Hotkeys work without clicking in grid first
Evaluation Timeout logic improved
Fix for keyboard shortcuts not working in Preview screen
FirstAlert re-enabled
FirstAlert now processes in batches of 100
FirstAlert Timeouts now 10 seconds applied to each action, SEND, RECV etc..
Updated Xceed DataGrid
Fix for large email headers causing fetching to stall
Fix for evaluation hang when duplicate WASH STARTs detected
Fix for crash when AutoSave of display settings fails
Fix for crash when when date rolls over
Fix for crash when sorting
Fix for crash Collection was modified; enumeration operation might not execute
Fix for crash on Filter creation
Fix for hanging when ABORT is called during login
Fix for the selected message to follow emails when sorted by Classification and the Classification is altered
Fix for not restarting properly when coming out of Sleep/Hibernate
Fix for Blacklist and Friends List purging most recent entries
Fix for Custom Filters not matching on some email subjects
Fix for MailWasher showing as active program when minimised
Fix for problem matching Friends and Blacklist against some addresses
Fix for grid not updating date columns properly after midnight
Fix for grid overlapping emails
Fix for evaluations not being completed
Fix for new mail notification firing on AutoDeleted emails
Fix for Quick Reply and Quick Forward not working with apostrophes in email addresses
Changes in 1.0.35 :
Due to some server issues we have been unable to resolve, this version will disable checking emails against FirstAlert by default. We are endeavouring to correct the issue as soon as we can and will advise when FirstAlert can be safely enabled without impacting performance on MailWasher. We apologise for these problems of late.
FirstAlert temporarily disabled by default
Added Swedish Language
MailWasher Aero display altered to be more respectful of standard Windows
Email List now updates display time after midnight
Added Source Program to Account Import Wizard to show where account came from
Added minimum resize limit for grid
Added back debug columns for Word Counts
Added ScrollBar when required to SideBar
Improved Wash Mail behaviour when deleting large numbers of emails
Opacity of the Display Options dropdown removed
AutoUpdater now deletes the old update file if it is ReadOnly
Fix for crash Index was out of range. Must be non-negative and less than the size of the collection.
Fix for crash Specified argument was out of the range of valid values
Fix for crash on corrupt BayesianSettings.xml
Fix for crash when Windows returns failure to open HTTP link
Fix for crash when Accounts file in use
Fix for close down time when machine is shutting down/logging off
Fix for AutoDelete not firing when a Language only filter is triggered
Fix for MW failing when UIDL is blank
Fix for New Lines encoded into message subjects
Fix for emails not being trained properly
Fix for lag when marking many emails as Read
Fix for ampersand symbol in a Friends or Blacklist entry failing to match
Fix for startup crash when columns don't exist
Fix for Bayesian rebuild occurring when not required
Fix for Recycle Bin automatically purging at 21 days
Update configuration files are now included with the crash/support logs
Setup files stored in [Common folder]/Firetrust/MWInstall in preparation for patching system
Misc small tweaks and other improvements
Changes in 1.0.27 :
Added Friends list and Blacklist expiry options by date age and/or total number
Various speed improvements
Quick Display is now Display Options
Right click menu to add to Friends/Blacklist now just take one click
Added option to disable the Aero display under Settings >> Display >> General (Vista/7 only)
Filter Edit screen can now be resized
Filter Edit screen improved on larger font scale
Preview Pane now loads selected email automatically when enabled
Scrolling in Preview area should download the full email even when there's no scrollbar
Email client now uses Registry path when opening to cater for programs with altered path
Email client now launched 1 second after Wash Mail completes
Fonts now embedded into application
Some Submenus now disable when appropriate
Added Hotkey DEL to delete items in Friends/Blacklists/DNSBLs
Added Hotkey / and * to mark as Spam or Good respectively
Added Hotkey ESC to cancel Custom Filter edit screen
Added basic Title bar menu for non Aero display
Added Version # to Automatic Crash Report email subject
Fix for adding sender to Blacklist removing Delete
Fix for hidden TaskBar not showing with MailWasher maximised
Fix for adding sender to Friends list marking all emails with Friend Status as Good
Fix for Friends/Blacklist not properly matching on some emails
Fix for Thai (and perhaps other) locales unable to be properly registered
Fix for errors on malformed emails being checked against FirstAlert
Fix for suspended automatic checks not always working
Fix for some emails missing Sent Date
Fix for Startup Animation freezing
Fix for large memory use marking many emails as Read
Fix for Custom Filter on Blacklist not triggering on Filter re-evaluation
Fix for crash in DownloadFullEmail
Fix for crash when access to Updater denied
Fix for crash when Performance Counters fail
Fix for crash 'Object reference not set to an instance of an object' when adding to Blacklist
Fix for crash when Wash Mail triggered twice
Fix for crash when Automatic Update set to check over every 30 days
Fix for crash when Quick Reply is triggered with no From address
Fix for crash when Registration check fails due to security policies
Fix for crash when Registering
Fix for crash Desktop composition is disabled
Fix for crash when default FavIcon missing
Fix for Recycle Bin not sorting properly on certain columns
Hardened STAT command/replies in MailWasherPro.exe
Hardened threads able to be terminated when they get hung
Other miscellaneous small fixes and improvements
Changes in 1.0.19 :
Added Delete All option into message list right click menu
Font zoom upper limit increased to 200%
Delete column now updates when a Custom Filter is disabled
MailWasher now does an automatic check on Resume (5 seconds after it comes back from sleep/switching)
Added troubleshooting option to use RETR instead of TOP into Settings >> Accounts >> Incoming >> Advanced
Speed improvement to AutoDelete
Speed improvement when selecting emails in list
Improved Language files
Fix for MailWasher opening under/over Task Bar
Fix for MailWasher not being able to check O2.co.uk and some other mail servers
Fix for crash/hang when MailWasher restores from System Tray
Fix for Blacklist not matching
Fix for Preview Window opening off screen
Fix for TellAFriend
Fix for Registration button not resizing
Fix for crash when sorting by Delete/Classification/Status or sender added to Friends/Blacklist when Custom Filters re-evaluate
Fix for incorrect characters displaying in Event Log
Fix for crash when DownloadFullEmail is triggered twice
Fix for selected message deselecting when MailWasher checks empty account
Fix for crash on error that I don't understand at all and cannot put into words
Miscellaneous minor tweaks and fixes
Re: New MailWasher Pro 1.8.0
Fri Mar 16, 2012 4:31 pm
Updated to reflect 1.11.0
Re: New MailWasher Pro 1.20.0
Tue Jun 12, 2012 5:01 pm
Updated to reflect 1.20.0
Re: New MailWasher Pro 7.1.0
Wed Mar 20, 2013 6:12 pm
Updated to reflect 7.1.0
Re: New MailWasher Pro 7.2.0
Wed Jun 12, 2013 3:25 pm
Updated for version 7.2.0
Re: New MailWasher Pro 7.3.0
Fri Nov 01, 2013 5:24 pm
Updated for version 7.3.0
Re: New MailWasher Pro 7.4.0
Thu Nov 13, 2014 2:32 pm
Updated for version 7.4.0
Re: New MailWasher Pro 7.5.0
Tue Feb 17, 2015 3:52 pm
Updated for version 7.5.0
Re: New MailWasher Pro 7.6.0
Mon Sep 28, 2015 2:49 pm
Updated for version 7.6.0
Re: New MailWasher Pro 7.7.0
Wed Nov 04, 2015 6:29 pm
Updated for version 7.7.0
Re: New MailWasher Pro 7.8.0
Tue Apr 19, 2016 2:46 pm
Updated for version 7.8.0
Re: New MailWasher Pro 7.9.0
Thu Feb 02, 2017 7:08 pm
Updated for version 7.9.0
Re: New MailWasher Pro 7.11.0
Wed May 24, 2017 5:42 pm
Updated for version 7.11.0
Re: New MailWasher Pro 7.12.6
Mon May 13, 2019 11:51 am
Updated for version 7.12.6
