the "Delete" button for accounts doesn't appear
alain17610
Fri Jun 06, 2025 3:31 am
Hello,
In Mailwasher Pro 6.4, the "Delete" button for accounts doesn't appear because the window hides it.
It might be below the "Add" button, but I don't know how to do it.
Resize the window? But how? :dunno
See you soon. ;)
Re: the "Delete" button for accounts doesn't appear
Fri Jun 06, 2025 6:58 am
Yes, this issue is usually caused by your screen resolution or custom font size is one that MWP cannot handle?
I'd try 'increasing' the screen resolution or 'lowering' the font size you use there...?
alain17610
Fri Jun 06, 2025 10:33 am
Thank you very much, gingbat.
It was by changing the size of the "active window border" in the display that I was able to make the "Delete" button appear.
Maybe see you soon.
Fri Jun 06, 2025 11:36 am
Excellent, good to hear you got it sorted there...! :)
alain17610
Sun Jun 08, 2025 5:29 am
After several attempts, reducing the size of the "desktop" fonts is indeed what allows the MWP window to shrink.
Thanks again, gingbat.
Sun Jun 08, 2025 8:29 am
:thumbsup
