Hideaway not connecting - need help
Charles984
Mon Jun 16, 2025 6:56 pm
Hi everyone,
I'm having trouble with Hideaway. All the shortcuts I set up before are no longer working. When I try to access it, I only see the cursor icon spinning continuously without connecting to anything.
I can't even access this forum when Hideaway is on. Only when Hideaway is turned off can I access it normally.
I've tried restarting my computer and checking my network connection, but the situation has not changed. Has anyone encountered a similar error? Looking forward to receivingChill Guy Clicker advice or instructions on how to fix it.
Thank you very much!
Re: Hideaway not connecting - need help
Mon Jun 16, 2025 7:26 pm
Hi
Which location are you connected to? Does Latency show -1?
