Apple Email Setup Fails in MailWasher
lockmeat
Wed Jun 25, 2025 8:21 pm
Hi everyone,
Long-time MailWasher user here. I recently tried adding my wife's Apple email account to MailWasher due to some troubling messages she received. Although the account setup appeared successful, I ran into a problem when configuring the incoming mail settings. The connection test shows as successful, but the event log reports an "UNKNOWN ERROR."
I’m using a Dell all-in-one PC purchased just last year.
Out of curiosity, I tried adding my own Apple email on the same machine and ran into the exact same issue — successful connection but “UNKNOWN ERROR” in the event log.
Has anyone else experienced this or know of a solution?
Thanks in advance,
Bunny
Chandlers
Re: Apple Email Setup Fails in MailWasher
Wed Jun 25, 2025 9:54 pm
I think you should try using an app password from Apple, as iCloud often blocks connections if not used properly.
Thu Jun 26, 2025 5:34 am
Yes, 'Chandlers' is correct, you'll need to enable app specific password settings on your account, (this is now a requirement from Apple)....
First, you have to enable two factor (NOT two step) authentication within your Apple ID:
https://support.apple.com/en-au/HT204915
Then, log into your apple account:
https://appleid.apple.com/account/manage
And under Security >> APP-SPECIFIC PASSWORDS, clicked, "Generate Password...."
And use that same password in MWpro using these settings:
(NOTE: don't add in the dashes apple shows for the password)
Any problems, please let me know.
