London IP Seems blocked on some sites
BBQs
Wed Jul 30, 2025 9:56 pm
Some sites such as https://malwaretips.com/ for example which I use daily & others are not loading or only partially - I'm on Paris at the moment which works fine but this means I can't access some local content on BBC for example. I realise some IP's are blocked because some users perhaps abuse things, but is there another London IP that could be used?? Best wishes Paul
Re: London IP Seems blocked on some sites
Wed Jul 30, 2025 10:10 pm
Hi
You can always select 'Watch UK TV' and that gives you some other IPs.
Alternatively, you can exclude websites from going via the VPN - see here how to do this. Bit of an overview, then scroll down...
https://firetrust.com/products/hideaway ... s-overview
BBQs
Wed Jul 30, 2025 11:34 pm
Watch UK TV works perfectly, I wasn't aware it would work with other sites so thanks for quick help !!!
