Flumuxed!
That implies a setup issue, there's nothing within the new MailWasher that would make a legitimate check that works take that long if it had no emails.It is much slower (the old version would check all my accounts within seconds - this has taken over three minutes so far to check one account.
Try sending the logs.....Help >> Send Support Logs >> enter chris as the Ticket Number >> include a brief description >> Send Logs...pepper wrote:I have reentered the password which I know works as I use it elsewhere. I still get "failed to connect to server".
I got the logs Pepper, I note the service provider indicates the POP server should be pop3.hosts.co.uk though I don't think that really matters, as when you connect to both servers they give the same reply 'NamesCo MUA Server'pepper wrote:I have reentered the password which I know works as I use it elsewhere. I still get "failed to connect to server".
