Dispatcher Error Message
taskiwi
Fri Sep 10, 2010 11:17 am
Getting an intermittent error message when deleting spam listed mail "Dispatcher processing has been suspended, but messages are still being processed." MW freezes and has to be re-started. Had a look through previous forum posts but cannot find a similar entry/query. Any comments from out there as I can't be the only one that this is happening to?
Re: Dispatcher Error Message
Fri Sep 10, 2010 11:29 am
Try going to your Settings, Accounts, Incoming Tab, Advanced Settings and Untick the Pipelining for Deleting Mail and see if that will resolve the issue. This may be a account specific problem if you have multiple accounts on different servers.
taskiwi
Fri Sep 10, 2010 12:13 pm
Thanks for the promt response and advice. I have done the setting changes and now will have to wait to see if this intermittent problem is fixed.
Fri Sep 10, 2010 9:30 pm
taskiwi wrote:Thanks for the promt response and advice. I have done the setting changes and now will have to wait to see if this intermittent problem is fixed.
After you get the crash, do you get prompted to send your Logs to us when MW restarts ?
