MailWasherPro and NetFramwork 4.0
- Conqueror
Does somebody know if MailWasherPro can be installed on a system with NetFramwork 4.0. For me MailWasherPro 2010 is not starting correect with NetFramwork 4.0. And NetFramework 3.5 can not be installed.
- nobodyspecial
- Pierre
- Knowledgeable Kea
Re: MailWasherPro and NetFramwork 4.0
- Conqueror
Is Microsoft the problemmaker, because .net 3.5 SP1 is not compatible to .net 4.0 ??
When somebody like me install his system new, than the option is that .net 4.0 would be installad, and no more .net 3.5 SP1.
So i really have to deinstall .net 4.0 and install .net 3.5 SP1 by hand ?
I khow and i can reed that MWP 2010 need .net 3.5 SP1. So what is the answer of my question before:nobodyspecial wrote:You need to have .net 3.5 SP1 installed to run MWP 2010.
- Pierre
- Knowledgeable Kea
It would be nice to know what M$ O/S you have installed. If you have W7 then .net 3.5 SP1 should already be on your PC.
- Conqueror
I have installed Windows 7 ! And i can start the software but whe i make a right hand click with the mouse on the IconPierre wrote:It would be nice to know what M$ O/S you have installed. If you have W7 then .net 3.5 SP1 should already be on your PC.
- After this picture nothing happen.
- Mail.jpg (11.84 KiB) Viewed 7894 times
- Conqueror
And this message also appears !Conqueror wrote:I have installed Windows 7 ! And i can start the software but when i make a right hand click with the mouse on the IconPierre wrote:It would be nice to know what M$ O/S you have installed. If you have W7 then .net 3.5 SP1 should already be on your PC.
- Conqueror
And now i see that I'm not the only one:
http://forum.firetrust.com/viewtopic.ph ... 31&p=33643
Conqueror wrote:And this message also appears !Conqueror wrote:I have installed Windows 7 ! And i can start the software but when i make a right hand click with the mouse on the IconPierre wrote:It would be nice to know what M$ O/S you have installed. If you have W7 then .net 3.5 SP1 should already be on your PC.
- Pierre
- Knowledgeable Kea
Sent PM to Rustic dog for you.
Conqueror : Can you email me a zipped copy of C:\Users\[username\AppData\Roaming\Firetrust\MailWasher\logs\ to [email protected]
