Vista Install Problem - Stopped at partial splash screens
kiwibloke
Mon Oct 04, 2010 9:57 pm
I have just installed Mailwasher Pro 2010 on Vista. Restarted computer. Mailwasher stalls at splash screens not matter what I try. What is the fix for this bug please?
Thanks,
Martyn
Re: Vista Install Problem - Stopped at partial splash screens
Tue Oct 05, 2010 10:59 pm
At a guess it would be your Firewall blocking access to MailWasherProApp.exe
Do you recall when you installed and started if your Firewall prompted for internet access for both MailWasherPro.exe and MailWashProApp.exe ?
Roy124
Wed Oct 06, 2010 3:38 am
I hd the same problem yesterday. It had been working fine but after a 4-day break it hung at th splash screen twice and grey screen once. Needed a reboot and that cleared it.
I am using Win7
