Problème de voir tout les textes qui sont a traduire.
SSTSylvain
Modérateur française
Thu Mar 03, 2011 1:17 pm
Hi, ...
Translation "French Quebec" "French Canadian" of MailWasher.
Traduction "Français Québécois" "Français Canada" de MailWasher.
J'ai un problème de voir tout les textes qui sont a traduire. Pour le moment seulement le fichier English contient tout les textes.
I have problem to see all texts that have to be translated. For the moment only English file have all texts.
SSTSylvain
Re: Problème de voir tout les textes qui sont a traduire.
Fri Mar 04, 2011 12:35 am
Many thanks Sylvain, we'll get this added.
sst wrote:Hi, ...
I'm not sure what you mean here, can you clarify for me please ?
SSTSylvain
Fri Mar 04, 2011 10:25 am
Hi, ...
rusticdog wrote:Many thanks Sylvain, we'll get this added.
sst wrote:Hi, ...
Respond = In clear, i have not all translatable line(s) inside "French Quebec" "French Canadian" translation file. Instead of the English translation file that contain all translatable line(s).
Thanks in advance, ... Please respond me soon as possible, ...
SSTSylvain
Mon Mar 07, 2011 4:48 pm
Right. MailWasher won't put translatable text into the French file until it's asked to display that text. So because of this you might see text in the English file that isn't anywhere in the other files. When you open the relevant options screen etc..that wants to display that text, then it will be put into the French file ready to be translated.
racker
Wed Mar 09, 2011 9:09 pm
rusticdog wrote:Right. MailWasher won't put translatable text into the French file until it's asked to display that text.
Ahhh good to know! So when removing all falsies we translators should first go through all screens in MWP to be sure.. right?!
Beta tester.. oh well! ;)..
MWP FAQ
Thu Mar 10, 2011 6:35 am
Could the programmers come up with a way to force all the lines to appear without the manual visiting?
Thu Mar 10, 2011 8:44 am
stan_qaz wrote:Could the programmers come up with a way to force all the lines to appear without the manual visiting?
Yeah, seems like there should be a backdoor for "Maintenance Purposes". :thumbsup :mrgreen:
15" MacBook Pro, OS X 10.10.5, 16GB RAM, w/ Parallels 11.x running Win7 SP1 Ultimate, Mozilla Thunderbird. All T'bird accnts: POP3. iPhone Mail Accounts IMAP. Unsubscrbd DNSBL.
racker
Thu Mar 10, 2011 9:11 am
That's a good one.. /me 2nd that! :thumbsup
MWP FAQ
Return to “Aide française”
