Account Name and E-mail address
Re: Account Name and E-mail address
Sun Oct 17, 2010 7:00 pm
What program are you having issue with? If it is MW version 5-6 or 2010 there are dedicated forums for that, if you are talking about your account settings for the forum...
It looks like you set the account name up already to "Frampton Rocks" so I'm not sure what problem you are having there. If you don't put your e-mail address in the forums you won't get the e-mail messages the forum sends you, some of which you must have to activate your account or to be contacted by the forum administrators.
Pierre
Sun Oct 17, 2010 7:04 pm
Please advise which version of MailWasher program you are running. I can then direct you to the correct forum to post your question.
This forum section refers to website problems only.
Mon Oct 18, 2010 3:43 am
Ah, a MW version 6 question, that needs to be asked here: http://forum.firetrust.com/viewforum.php?f=13
The "Frampton" portion of my answer was if you were asking about the forum account settings.
veerji
Nice
Fri Sep 28, 2012 6:47 pm
I've posted this message 'cause I'm having trouble understanding something, when I come to type in Account Name what exactly should I put down, for instance:
Sat Sep 29, 2012 2:46 am
The general preference is to type one's <first> and <last> name - it anyways does not impact the working of MWP.
Sat Sep 29, 2012 4:52 am
I have several accounts so I use the ISP, then an account identifier:
Cox Stan
Cox Bugzilla
WH Stan
WH Suse
Gmail Stan
SKP Stan
SKP Forum
