Hi there,
I am getting this error on our SBS2003 server at the moment, i have restarted the server, but that hasn't solved the problem. The mailwasher service is running and i can access the monitor. What can be cause of this ? I am using the latest version of the mailwasher (2.7.81)and i ahve got screen-dumps if requested.
MWES.EXE encountered a problem and needed to close
- Antoniusfm
- MWES_errors.zip
- Some screen-dumps
- (47.37 KiB) Downloaded 1144 times
- nick.bolton
- The Big Cheese
Re: MWES.EXE encountered a problem and needed to close
Hi there, sorry for the late reply as we had an earthquake and we're getting ourselves back on track again.
If you download and use this update, it should fix the crash problem you're seeing. We'll be releasing this version soon as the official release.
http://firetrust.com/sites/firetrust.co ... ler-28.exe
Regards
Nick
Regards
Nick
- Antoniusfm
No worries Nick, thanks for your update, i hope you guys didn't get to much grieve from the quake !
I have installed 2.8, and will let you know if there are still problems, i did notice a message indicating that i am using a outdated version and that 2.7.81 has been released, you probably want to update that in your official release.
Furthermore the system status indicates "Starting..." (even after restarting the service), shouldn't it say "Started" or "Running" ?
Thanks again, and good luck with the recovery !
- nick.bolton
- The Big Cheese
Thanks, we're pretty well all ok now.
We've got that 'old version' fixed and I'll notify the developers about the 'Starting'.
Nick
Nick
