[Tutorial]: Change The TASK BAR Icon From Soap To Drain Plug
Sun Sep 18, 2011 10:30 pm
This guide will assist Users of Window 7 in changing the MailWasher Pro 2011 'task bar' icon into any other icon. Since many members love the previous icon from the V6 series, this tutorial has been molded around the 'Drain Plug' and the overall objective is to arrive at the following result:-
Tutorial (1).png (358.96 KiB) Viewed 13032 times
01.) Download the icon (Drain_Plug.ico) from either of the following sites:-
http://www.mediafire.com/?tb348incn8v26tw
or
http://www.multiupload.com/ZZA8U18FGD
02.) Save the downloaded (Drain_Plug.ico) to a convenient directory - as an example, let's assume the following directory:-
C:\Users\Your User Account\AppData\Roaming\Firetrust\MailWasher
03.) Next, just follow the simple instructions in the following illustration:-
Tutorial (2).png (229.5 KiB) Viewed 13032 times
04.) After clicking 'Change Icon,' browse to the directory (C:\Users\Your User Account\AppData\Roaming\Firetrust\MailWasher) where the Drain_Plug.ico was saved and then select it
05.) Restart MailWasher Pro 2011 and that's about it.[/color] :thumbsup
Important:
You need to configure your 'Taskbar buttons' to 'Always combine, hide labels.'
Sun Sep 18, 2011 10:33 pm
Those who would like to have their own (.pdf) copy of the above tutorial can download the same from either of the following links:- (1.39 MBs only) :thumbsup
http://www.mediafire.com/?2qflytcd7t4rke4
or
http://www.multiupload.com/W8UECAXMIA
Re: [Tutorial]: Change The TASK BAR Icon From Soap To Drain
Mon Sep 19, 2011 3:06 am
Why not load the images to the forum so folks don't have to change their security settings to see them?
Forum blocks .ico filetype so it is zipped:
MailWasher_MAINICON.zip
(42.37 KiB) Downloaded 562 times
Mon Sep 19, 2011 5:23 am
The external servers offer superior image rendition and about the security settings, I'm not sure what you're referring to - using Firefox here (on an ultra-tight security policy) yet no sweat at all. Files like .ico or for that matter - any extension is never blocked on those servers hence, need not have to be zipped, either ;)
johno
Mon Sep 19, 2011 8:22 am
I used your icon and now see it in my quick launch tray and my system tray (when the app doesn't implode on launch or first fetch, that is :barf ) but not in my taskbar. Any ideas?
johno
Mon Sep 19, 2011 11:56 am
You can right click the MWP icon - the yellowish one in the task bar and then just follow the guide (MWP is required to be restarted for the necessary change in icon to show up.) :thumbsup
By the way, been running the Drain_Plug icon and several other icons (as per my mood swings) for over a couple of months - no implosions (or explosions) ever experienced, here.
:D
Mon Sep 19, 2011 12:02 pm
If the above does not work, right click an empty area on your taskbar and click 'Properties' and then on the drop-down menu of 'Taskbar buttons' - you need to select 'Always combine, hide labels.'
johno
Mon Sep 19, 2011 7:28 pm
TrustFire wrote:If the above does not work, right click an empty area on your taskbar and click 'Properties' and then on the drop-down menu of 'Taskbar buttons' - you need to select 'Always combine, hide labels.'
Taskbar properties doesn't appear to give me the 'Always combine, hide labels' option on 32bit Vista :frown
johno
johno
Mon Sep 19, 2011 7:39 pm
TrustFire wrote:You can right click the MWP icon - the yellowish one in the task bar and then just follow the guide (MWP is required to be restarted for the necessary change in icon to show up.) :thumbsup
:D
Right clicking on the MWP taskbar icon does nothing useful on 32bit Vista :gag
The taskbar icon does at least vanish if I minimise to system tray so I don't have the offending bar of soap in view all the time :thumbsup
johno
Mon Sep 19, 2011 7:57 pm
Sorry about that Johno, did not realize you're on Vista - the 'Always combine, hide labels' setting is mandatory for the above guide to work and unfortunately, is not available on Vista. Have made the necessary alterations to the first post. :oops:
johno
Tue Sep 20, 2011 4:26 am
TrustFire wrote:Sorry about that Johno, did not realize you're on Vista - the 'Always combine, hide labels' setting is mandatory for the above guide to work and unfortunately, is not available on Vista. Have made the necessary alterations to the first post. :oops:
Da nada :mrgreen:
johno
Sat Oct 22, 2011 7:01 am
Here's a superb specimen.
This icon needs to be converted from (.png) to (.ico)
MailWasher Pro 2011.png (62.06 KiB) Viewed 13069 times
Wed Feb 01, 2012 2:53 pm
Moving this into the public forum, as someone has asked about doing this.
Fri Feb 03, 2012 3:59 pm
@ rusticdog
cheers :thumbsup
stan_qaz wrote:Why not load the images to the forum so folks don't have to change their security settings to see them?
. . . . . . . done - images uploaded to FireTrust servers!!!
Maureen
Fri Feb 24, 2012 3:49 am
That's great news BUT I still use Windows XP Pro :-((
Remember the Universal 'Law of Attraction'. You attract into your life that which you want, or fear the most!!
