HA disappearing several times each day
Zooi
Thu Aug 01, 2019 6:12 pm
A couple of days ago I bought, installed and started using HA. Every day so far during the day HA disappears several times and I have to start the program again. This is no good as I now never know if the program is still running. I have to keep watch if it is still running, but when I am away from my PC I cannot notice if HA is still running or has disappeared again :(
Any suggestions?
Greetz,
Zooi
Re: HA disappearing several times each day
Thu Aug 01, 2019 6:15 pm
Hi there, sorry about this. We have one other user with this issue as well. He's running torrents all the time and it occasionally fails. Are you also running torrents? If so I'll send you a special build which will give us some information about the problem.
Zooi
Thu Aug 01, 2019 6:56 pm
I sometimes use torrents. Not every day.
I just restarted my PC, which I hadn't done since installing HA. I also started HA. Let's see what happens.
Greetz,
Zooi
Zooi
Thu Aug 01, 2019 10:03 pm
Just now I noticed HA disappeared.
I have only surfed on the web and did not download torrents.
I'll now restart HA
Greetz,
Zooi
Fri Aug 02, 2019 5:43 am
Could you please send us the logs?
Go to Start, type Run, and click enter. Then type %appdata% and press enter
Go to the 'HideAway' folder and upload the log.log file.
Thanks!
Zooi
Fri Aug 02, 2019 12:30 pm
Herewith the log.log file
log.log
(4.01 KiB) Downloaded 376 times
Greetz,
Zooi
Fri Aug 02, 2019 3:38 pm
Thanks, we're releasing a new version on Monday with some changes which will hopefully fix this (along with more locations).
Zooi
Fri Aug 02, 2019 7:29 pm
OK, I'll wait for that and indeed hope that it works.
Greetz,
Zooi
Fri Aug 02, 2019 8:56 pm
Just wondering if when you see HideAway disappearing, is it still in the System Tray and can you click on it to get it working from there?
Zooi
Sat Aug 03, 2019 2:45 am
I can see it in the system tray, but when I hover over HA (that is how I find out if it doesn't work) it fades and then disappears. Also in Task Manager it doesn't show anymore.
Greetz,
Zooi
Mon Aug 05, 2019 8:44 pm
Missed todays update, so it will be tomorrow now
Tue Aug 06, 2019 8:30 pm
You should be able to get the update now by restarting HideAway. Hopefully this fixes your issue, otherwise we have some other ideas.
Wed Aug 07, 2019 6:04 pm
Ok, can you please give this a try
I don't think 4.1.4 fixed the issue, but this might.
