Still servers are really slow
king
Fri Jul 02, 2021 11:05 pm
Hideaway was the fastest vpn service I ever had. but recently after that server outage whatever the server I connect, it's really really slow comparing to without vpn connection. I won't get more that 20-30% of my original bandwidth when I connect to VPN server. Is it only me having this issue or it's occurred to others as well? :scratch :gag
Re: Still servers are really slow
Sat Jul 03, 2021 11:45 am
Which server are you trying to connect to?
We're doing an update this weekend to fix some issues there.
poundgirl
Sat Jul 03, 2021 5:09 pm
I'm connected to 'Watch UK TV' and have given up trying to stream anything :(
Lord, help me to be the kind of person my dog thinks I am.
And if there are no dogs in Heaven, then when I die I want to go where they went!
Sat Jul 03, 2021 5:40 pm
Give this version a try. It fixes the server slow downs we were having and should be significantly faster, just updating the servers but only up to countries starting with I.
But have done the 'Watch UK' ones so see if it helps.
Shutdown HideAway first, then install this one.
Or what was the issue with streaming from these 'Watch UK' servers? Did they detect a VPN, or were they just slow?
poundgirl
Sat Jul 03, 2021 5:51 pm
Hi Nick,
It connected OK but it was just continuous buffering and so quite unwatchable. I started downloading the program instead but it's just crawling along.
I'll try reinstalling that version and let you know how it goes ...
poundgirl
Sat Jul 03, 2021 6:30 pm
Before I uninstalled I noticed the download had sped up considerably so I tried streaming again and it was fine, Whatever you did Nick it worked great so thanks!
thepuppiespie
Sat Jul 03, 2021 10:46 pm
Start with the performance monitors and see if your Disk, CPU, RAM, or Network Traffic performance is normal/acceptable.
Puppiespie #1 Plateform That Provide you to Get Best information About Pet, Price and Related Products (puppiespie) That help to make Your decision. Believe Me Pitbull is the best dog ever.
king
Sun Jul 04, 2021 4:02 am
Mainly, Singapore. but other servers also same issue.
king
Sun Jul 04, 2021 4:27 am
Thank you. Thank you... :bow this version improves it really well. almost perfect again.. :thumbsup :bow
Sun Jul 04, 2021 9:29 am
Great, just updated Singapore too so that should be working better.
poundgirl
Mon Jul 05, 2021 10:32 pm
Nick, this morning I got the same go slow on the UKTV redirect so thought I'd give your suggestion above a go. I didn't read the post post properly though and realised afterwards I was just supposed to completely shut down and not also uninstall. I tried to install again from your link above and got the dreaded ‘Unable to initialise hideaway driver: FAIL’
I also tried to go back to the current version but still get the same message :help
I've attached the logfile ...
SquirrelSetup.log
(21.43 KiB) Downloaded 399 times
Tue Jul 06, 2021 6:34 am
You'll need to uninstall HideAway, restart your PC, then install it again
poundgirl
Tue Jul 06, 2021 11:31 am
There's nothing to uninstall now as this is as far as I get when I try to reinstall and then Hideaway just shuts down :(
I always do a restart after I uninstall anything ...
Hideaway Driver Fail.jpg (53.7 KiB) Viewed 9175 times
Tue Jul 06, 2021 12:32 pm
Can you please do this.
Click start -> search for cmd -> right click -> choose “run as
administrator", then type (or copy/paste) the following and press enter after each line.
cd %LOCALAPPDATA%\HideAway\app-4.17.3\resources\app\driver
HideAwayDriverSetup.exe -u
Restart Computer (not Shutdown)
Run cmd.exe as Administrator, and type
sc query hideaway
Should say something like
[SC] EnumQueryServicesStatus:OpenService FAILED 1060:
The specified service does not exist as an installed service.
Run cmd. exe as Administrator, and type
HideAwayDriverSetup.exe -i
sc query hideaway
SERVICE_NAME: hideaway
TYPE : 1 KERNEL_DRIVER
STATE : 4 RUNNING
(STOPPABLE, NOT_PAUSABLE, IGNORES_SHUTDOWN)
WIN32_EXIT_CODE : 0 (0x0)
SERVICE_EXIT_CODE : 0 (0x0)
CHECKPOINT : 0x0
WAIT_HINT : 0x0
Run HideAway
Redirect: All Computer
to
USA, Los Angeles
Go to ipinfo.io confirm it works
Did that help?
poundgirl
Tue Jul 06, 2021 3:40 pm
Thanks Nick ... that did the trick!
I think they're the same instructions you gave me when I got that same response after installing Windows 10 so I'll file them away so I don't have to bother you if it happens again :D
