Windows 10: v10.0.19045 Build 19045
Mailwasher Pro v7.12.173
.NET v4.8.1
My Mailwasher Pro just started closing on its own today. When I move my mouse over the icon in the system tray, it closes out. I can restart MWP, but again, as soon as I move the mouse over the icon, it closes out. I've tried starting the application as "Run as Administrator" and it still does it. I've rebooted my computer, and it still does it. MWP had been working fine all day, and then started doing this. No updates for the computer in several days. In Event Viewer I am seeing 2 events for Mailwasher Pro, one after the other, each time it closes out.
Application:
Faulting application name: MailWasherPro.exe, version: 2023.7.12.173, time stamp: 0x64eabb1f
Faulting module name: MWPappDLL.dll, version: 0.0.0.0, time stamp: 0x64e8204c
Exception code: 0xc0000005
Fault offset: 0x000df5c4
Faulting process id: 0x5c3c
Faulting application start time: 0x01d9dd57ccb56a78
Faulting application path: C:\Program Files (x86)\Firetrust\MailWasher\MailWasherPro.exe
Faulting module path: C:\Program Files (x86)\Firetrust\MailWasher\MWPappDLL.dll
Report Id: 992fa402-39fe-489c-bed0-70ad14881399
Faulting package full name:
Faulting package-relative application ID:
.NET Runtime
Application: MailWasherPro.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: exception code c0000005, exception address 1802F5C4
Mailwasher Pro 7.12.173 Closes after Opening
- robert
- tsolna
Re: Mailwasher Pro 7.12.173 Closes after Opening
Same problem here Saturday morning too. Version 7.12.173
- furax69
Same issue on my side...
I tried on three different computers (desktop W11, Laptop Asus W11 and mini PC under W10)... In all cases, Mail Washer closes abruptly after a few seconds...
I also tried to clear the cache... Uninstall and reinstall... Same problem... So I think the latest version has a serious problem!
I just contacted the support... Hope a quick answer
Let see
Let see
- trois
Same
Updated to 173 a few days ago - working fine until now - MW disappeared from the taskbar. Restarting, it checks several accounts and then crashes - consistently.
Win 10 Pro x64 (up to date, but on checking, it installed (without consent!) this .NET update (preview!) - .NET got mentioned in @ucon 's log)
Had to restart PC - no dice.
It's a license issue.
- 2AUL06kDgg.jpg (42.05 KiB) Viewed 8080 times
- emmrecs
Same problem here!
Opened MW this morning, it started to download new emails, began "checking" them and then crashed, repeatedly. I then restarted my computer (to check whether there was a problem with the system booting) opened MW and it crashed again almost immediately!
No chance of accessing MW error logs, it crashes too quickly!
- JohnBlase
Same issue here. Program ran fine, as long as the date was August. As soon as September 1 came along, the program started to crash repeatedly. Will not stay operational long enough to function.
- jxm2
Same.
Downloaded update a few days ago, worked fine.
Ran it this morning (2nd Sept), keeps just closing with no error.
It does stay alive if there is no email to check, but if there is any email as soon as it tries to check it the program closes...
- MarcJEpstein
It is happening to me also. Yesterday it ran fine. This morning when it was opening, it downloaded the emails I received since last night. When it started to evaluate them, after about 6 seconds or so, it just closed itself. It happened around 10 times when I decided to look for help.
I am running the latest version of Windows 10 Home X64 and I updated my MWP a couple of days ago to the newest version 7.12.173.
I just unchecked the FirstAlert box shown in another post in this subject. It does work. When they fix the problem, hopefully it will be in an automatic update and that they let us know, so that we can recheck this box.
- headbanger51
Exactly same issue after update to MWP 17.12.173. Latest version of Windows 10 Home X64.
- furax69
No news from support... My ticket still pending
- Lantern
- jpwd57
Mi2 hetzelfde probleem. Sinds vanmorgen crasht mailwasher met Windows 11 laatste updates.
- bigbbdriver
Same here, bloody nuisance!
Can't even download a previous version as links don't work!!
I've uninstalled and reinstalled version mailwasher_pro_setup_7_12_125, which works ok.
