MW 2010
tomcatuk
MW 2010
Tue Aug 24, 2010 2:33 am
I did read somewhere somebody asking how do they know if first alert is working but can't seem to work out if I have any numbers where they suggest as its very feint on my screen maybe if I had some mail there it might show something.
Just wonder if you have fixed the checking mail between these times option yet whereby if I ask for the mail not to be checked between 19:00hrs - 08:00hrs it continues to check up to 00:00
Is there a list anywhere of things to do to save reporting problems you already know about?
Keep up the good work...
Steve
Re: MW 2010
Tue Aug 24, 2010 2:52 am
Hi Steve
If the numbers are faint that just implies there was no hit on that email. Under Help >> User Files >> Logs >> logs_[todays date] >> look for the MWP_FirstAlert.log and open this in Notepad, if you see lines like this
Code: Select all
08-23-2010 21:28:49.015	Info	C: 2 ContentCheck 0 101 11341 b567c891c6b4bfb20055e723e85ed9d4 1027 00000000000100000000000000000000000400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000700
08-23-2010 21:28:49.652	Info	C: 12 ContentCheck 0 101 229440 199d213b2316ae195076e0c551cd4304 1027 01000100000100010000020102010003010406010000010000000200000001010102000000000403000000000101000100000002010000010000000101000302
08-23-2010 21:28:49.656	Info	C: 13 ContentCheck 0 101 348406 74afd4dd416181a3b8444ad404627a57 1027 01010100000101000000000200010200000406000001020100000400010000010001010101000100000000020001030000000102000002000100000100000000
Then it's working.
As far as I'm aware we've fixed all issues with the automatic check timer, there is no list online of things known unfortunately.
Re: MW 2010
Tue Aug 24, 2010 5:50 am
Here are a couple shots of FA hitting and missing:
Miss:
Hit:
I'm finding that the 80 line throttle setting minimum for FA works but I seem to do better with 100-200 lines there instead. Also the more often I check mail the lower the FA hit rate goes as I'm getting the mail before FA gets a chance to collect it and add it to the system.
There is a suggestion to provide an indication if there is a FA problem, you could add a vote or three to that if you liked.
http://www.firetrust.com/en/products/ma ... er-is-down
tomcatuk
Re: MW 2010
Thu Aug 26, 2010 4:12 am
rusticdog wrote:Hi Steve
Thanks for the reply....
I have my settings to not check for mail between 18:00 - 09:00 and it continues checking up to 00:00
I have it set to check for mail every 60 minute's and will send another log tomorrow.
Steve
mcullet
Re: MW 2010
Thu Aug 26, 2010 5:04 am
Hi Folks ...
FA - hits and missing images???
Ummmm ... I looked under the desk and I swear I don't remember where I left it.
Seriously though ... where do I look and Stan ... where were you when you took the family pics (nice too)
Just noticed this at the end of a Firetrust PM notification email: "Thanks, your new Firetrust Overlords." So true .... so very true :bow
(Never underestimate the power of a good sense of humour - whoever wrote that is a god of good taste.
EDIT: Found the logs. Doh! Thought you were giving windows folders as opposed to MWP menu items. I've got WIN 7 - and when I searched on the file name RD gave, nope ... couldn't find it. Which means it's hiding in one of the "stay away or die" folders?
I am curious about the pretty pics from Stan ... I want one too.
Mike
MOBO - GA-Z68XP-UD4 (rev 1)
Re: MW 2010
Thu Aug 26, 2010 6:16 am
No clue how to do screenshots in Windows, mine are all taken from my Linux box using Ksnapshot.
I just enabled the spamtools sidebar to get the images up, you have off, wide and narrow options for displaying it and you can move it around the screen with the quick display menu.
anniebrion
Re: MW 2010
Thu Aug 26, 2010 6:22 am
stan_qaz wrote:No clue how to do screenshots in Windows, mine are all taken from my Linux box using Ksnapshot.
I do screenshots with Snagit10 but if you press PrtSc then Ctrl-V in paint this will capture the whole screen, then you can trim the bit you want.
Re: MW 2010
Thu Aug 26, 2010 2:24 pm
And CLTRL + ALT + PrtSc to just take the screen shot of the currently active Window, not the whole desktop
